Автор Тема: ПОПРАВКА в архив  (Прочитано 4525 раз)
  • Репутация +315/-298
« : 12 Апреля 2009, 00:48:42 »
К-9-РЕЛЕ ВКЛЮЧЕНИЯ ЗАДНИХ ПРОТИВОТУМАНОК ПРИ ВКЛЮЧЕНИИ ДАЛЬНЕГО СВЕТА
мда и заднии противотуманки у меня работают только с дальним светом
Рекомендуем почитать по теме ПОПРАВКА в архив
« Ответ #1 : 13 Апреля 2009, 12:00:33 »
1 7.5 Left high beam headlight(relay K3)
2 7.5 Right high beam headlight(relay K3)
3 15 Auxiliary fan, 91°C(relay K1)
4 15 Flashing turn indicators
5 30 Wipe-wash, headlight cleaning and intensive cleaning systems(relay K10)
6 7.5 Brake lights (15A if additional brake lights are fitted), automatic cruise control, map reading lights
7 15 Horn(relay K2)
8 30 Heated rear window
9 15 Selector lever position indicator for automatic transmission
10 7.5 Instruments, on-board computer, reversing lights, Service Indicator
11 7.5 Fuel pump, fuel supply pump
12 7.5 Radio, Check Control and instruments
13 7.5 Left low beam headlight(relay K4)
14 7.5 Right low beam headlight(K4)
15 7.5 Rear fog lights (relay K4), switching off when high headlight beams are selected(relay K9)
16 15 Seat heating(relay K5)
17 30 Sliding roof (relay K5)
18 30 Auxiliary fan, 99°C(relay K6)
19 7.5 Mirror control, mirror heating(relay K7)
20 30 Heater blower, air conditioning(relay K7)
21 7.5 Interior, glovebox and luggage compartment lights, torch, clock, radio memory, on-board computer
22 7.5 Left side, rear and parking lights
23 7.5 Right side, rear and parking lights, licence plate lights, instrument lighting
24 15 Hazard warning flasher
25 30 Not in use
26 15 Touring: rear-window wipe-wash system
27 30 Central locking system, door lock heating, on-board computer horn, Sound System
28 30 Cigarette lighter, motor-driven radio aerial, independent fuel-burning heater
29 7.5 Left fog light(relay K8)
Сообщение склеено: [time]Пнд 13 Апр 2009 10:01:39[/time]
см 15 предохранитель и комментарий к нему
у этцольда тоже написано ВЫКЛЮЧЕНИЕ
Сообщение склеено: [time]Пнд 13 Апр 2009 11:04:11[/time]
кстати, ув. модераторы! предлагается в таблицу предохранителей на главной странице добавить информацию о соотв реле, как это выше приведено
« Последнее редактирование: 13 Апреля 2009, 12:04:41 от Canon
« Ответ #2 : 13 Апреля 2009, 12:11:38 »
я так понял выключает при отключении дальнего света, я не спец по английскому-но у меня так,и при этом точно нет колхозя
« Ответ #3 : 13 Апреля 2009, 12:30:47 »
дословно
выключаются при выборе ламп дальнего света
  • Репутация +10400/-111
  • Локация: Украина, Донецк
« Ответ #4 : 13 Апреля 2009, 12:39:32 »
Ну правельно всё, при дальнем свете противотуманки не нужны!!!
Как ты будеш ехать при тумане если фары дальнего буду светить вверх???
095-359-33-13   063-246-43-52
« Ответ #5 : 13 Апреля 2009, 12:42:14 »
СТРАННО может реле у меня чего не так делает
« Ответ #6 : 13 Апреля 2009, 12:58:26 »
может просто не то реле
« Ответ #7 : 13 Апреля 2009, 13:06:28 »
мда да там вроде стандартное как на свет,может они тоже чем отличаются?
« Ответ #8 : 13 Апреля 2009, 13:52:35 »
ну типа должно стоять размыкающее а у тебя замыкающее
